AutoCAD 2013/2014/2015
vikasranga2
Message 1 of 5 (19,455 Views)
How to fill up color in polygons?
19455 Views, 4 Replies
06-16-2012 05:16 AM
I have a drawing (.dwg) file. It is having so many polygons created by polyline. I want to fill up those polygons by a color. How can I do the same in AutoCAD?
After that How can I generate .svg from .dwg?
Patchy
Message 2 of 5 (19,451 Views)
Re: How to fill up color in polygons?
06-16-2012 05:36 AM in reply to: vikasranga2
Hatch with solid.
Attach your example drawing here, let's see.
pendean
Message 3 of 5 (19,446 Views)
06-16-2012 06:48 AM in reply to: vikasranga2
Look up and start HATCH command.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
vikasranga2
Message 4 of 5 (19,420 Views)
06-18-2012 02:36 AM in reply to: pendean
Sorry for late response,
I am not getting required result using hatch tool.
Actually I have so many polygons in a drawing (.dwg) file. Using hatch file, I am able to select only one ploygon at a time. I need a script which can hatched all objects at a time.
Can we apply hatch tool on all layers simultaneously?
pendean
Message 5 of 5 (19,408 Views)
06-18-2012 05:47 AM in reply to: vikasranga2
No, HATCH command requires some sort of selection of objects or spaces: you can explore using QSELECT or FILTER or SELECTSIMILAR commands to create such selections based on whatever criteria they all share in common.
AFAIK you can select more than one at the same time, you just need to be aware of your hatch "island detection" settings of these objects overlap. Also look up and set HPSEPARATE variable to what you need.
