¿How to export .3ds from Autocad 2014?
I want to export to .3ds ; Then import 3ds with KeyShot. Because if I import dwg in KeyShot, the faces are faceted.
I think the .3ds is the only format that puts me autosmooth in a solid 3d.
Solved by Alfred.NESWADBA. Go to Solution.
exporting to 3DS format is not supported since AutoCAD 2008 (if my remebering is ok).
To export geometry for visualization use the FBX-format instead and then you can convert it (using >>>FBX Converter<<<) to many formats used by rendering/visualization systems (if FXB is not supported directly).
For geometry the 3DS format has limitations (like the number of vertizes per object/mesh) that makes it not easy to transfer data nowadays.
- alfred -
>> I make a simple sphere, a 3D solid, and exported to .fbx
Can you upload that drawing?
- alfred -
>> exported to .fbx, tell me something like...
>> You can not export any of the specified objects...
Sorry, my brain seems to get (small) black holes 😉
We had that some times ago .. the difference is if you start command _EXPORT and then chose type FBX or if you start command _FBXEXPORT.
First does not work, second command works (same issue with 2015, not repaired).
- alfred -
