AutoCAD Forum
How to enable "shaded viewport options", "shade plot" in Layout
2 REPLIES 2
22262 Views, 2 Replies
In my Autocad i can't change "shade plot" in shaded viewport options. it doenst allow me to change. Because it is desable I dont know how to enable that.
2 REPLIES 2
nestly2
Welcome to the Autodesk forums.
As far as I know, that's only enabled when plotting from Modelspace.  It's disabled when plotting a Layout because Layouts can have multiple viewports, each with their own shadeplot, so you can set it singularly.
To control the Shadeplot for a layout, select the viewport(s) and adjust the Shadeplot with the Properties Palette.  By default, each Viewport will plot the current Visual Style (As Displayed)  unless you assign a different Shadeplot.
in reply to: nestly2
i just found how to change it to "as displayed". with the command "mview" - "shadeplot" and "as displayed" i can change it. i wanted to set it in plot settings but at least it is enough for me. Thanks for help :):)
”Boost
