Is there any way to edit view properties by properties palette ?
In properties palette, the view properties are grayed out, but the quick calc is active.
How can I edit the view properties by quick calc ?
Any help would be appreciated.
~sandeep
Solved by jggerth. Go to Solution.
Here is the screenshot.
All the view properties are grayed out, but the quick calc is active. Why?
The role is apparently that you can open it, and do math.
And no, there's no real point in it being available at that moment, from that interface locatin. It's just that the place you are at is a Number field in the palette, and number fields include an access for QuickCalc. The programmers did not bother generating a special subclass of NumberFiledsWithOutQC, but simply used the one that existed.
A good call on their part, otherwise the wrong subclass of number fields would show up where there's actually a use for QC
