Does anyone know how to edit an array path, or show the array path after its been deleted? I am trying to respace my array, and cannot space them apart enough because the path (a line) I created was too short. However, I have already deleted the path and saved the file a few days ago. Now I can't seem to show the path, or even copy the original object to re-create an array. Any suggestions would be great!
I had the same issue. What worked for me is changing the "Fill Entire Path" option in the Properties, under Misc section of Properties. If you change Fill Entire Path to No, an arrow will appear at the end of the path which you can move along the path to add or remove to your array. Hope this helps.
