Solved by jraiz. Go to Solution.
maybe some more details?
is there a direct support path to it? what is the arx file/app? and why do you need to unload it?
Search for the name of the application in the contents of files in your support path. If you are on Windows 7 + search will not do this by default so you may have to modify your settings. See Search Contents
Once you've found the culprint comment it out.
Edit: I just tried the "contents" setting as described and it did not work as I expected. (Grrrrr) In the past I've used a utility program called Wingrep grepWin to do this which works well.
Appload isn't the only way third-pary applications can be loaded:
- the first ACAD.RX file in the search path will attempt to load the contents
- a shortcut may specify an /ld argument (this is frequently used with AutoDesk vertical programs)
- a .bundle may be present
- an MNL file from an associated CUIx file (or other LISP or code source) may be issuing a load call
- the first ACAD.LSP or ACADDOC.LSP file may be issuing a load call
- a demand-load section can be present in the registry
Is it in the Startup Suite? It's not clear to me whether that's what you mean by having removed it "from the appload." If you meant something other than that, type APPLOAD [or its alias, just AP], and look at the Startup Suite's Contents [if any]. If it's there, Remove it.
