AutoCAD Forum
How to customize the scale
3 REPLIES 3
seiya.kumada
246 Views, 3 Replies
We are now implementing a plugin for the AutoCAD2013 using its SDK.
The plugin loads a image file(png format) and display it on the viewer of the AutoCAD.
Because the size of the image is now 640x640 pixels, pop-up values which are shown on the viewer when clicking by mouse are in [0,640].
We would like to change the scales.
For example, we want the pop-up values to be three times as much as the current ones.
Could you tell us how to change the scale using the SDK?
3 REPLIES 3
in reply to: seiya.kumada
seiya.kumada
Hi fredrik,
Thank you for your help.
hgasty1001
SDK, which one?, Autocad has multiple APIs: .NET,Autolisp,VBA,C++,JavaScript. Also I don't understand what you mean with: "on the viewer of the AutoCAD". is it the drawing editor, a form, etc? What dou you mean with: "pop-up values".
You can ask, and post the code in some of the specific forums for each API.
Gaston Nunez
”Boost
