We are now implementing a plugin for the AutoCAD2013 using its SDK.
The plugin loads a image file(png format) and display it on the viewer of the AutoCAD.
Because the size of the image is now 640x640 pixels, pop-up values which are shown on the viewer when clicking by mouse are in [0,640].
We would like to change the scales.
For example, we want the pop-up values to be three times as much as the current ones.
Could you tell us how to change the scale using the SDK?
Solved by hgasty1001. Go to Solution.
SDK, which one?, Autocad has multiple APIs: .NET,Autolisp,VBA,C++,JavaScript. Also I don't understand what you mean with: "on the viewer of the AutoCAD". is it the drawing editor, a form, etc? What dou you mean with: "pop-up values".
You can ask, and post the code in some of the specific forums for each API.
Gaston Nunez
