I have a drawing that I really like, I saved it as drawing 1, uncolored.
I also want to copy the same drawing to different .dwg files, but I want 4 different colors of it.
So, how do I copy the same basic drawing to 4 different files, so that I can color each one with different colors, and maybe a few different shapes?
Thanks in advance,
Sincerely,
Noob.
from your drawing start to use WBLOCK command after changing colors as your need .
I would probably use SAVEAS, changing the colors as needed between each SAVEAS, but I'm wondering whether you really need multiple copies of the same drawing, or whether perhaps a better approach would be to reuse the original drawing by inserting it as a block or xref and altering the color inside the destination drawing?
