AutoCAD Forum
how do i turn off icon next to crosshairs
7 REPLIES 7
Message 1 of 8
andrew.nao
17774 Views, 7 Replies
the icons that appear next to the crosshairs when you do, for example the erase command, how do i turn that off? (see attached picture)
7 REPLIES 7
Message 2 of 8
nestly2
in reply to: andrew.nao
The short answer is you can't turn them off.
Here's a related topic and a suggestion by an ADSK employee how to give feedback.
http://forums.autodesk.com/t5/AutoCAD-2013-2014-2015/AutoCAD-2015-Selection-Cursor-Badge/m-p/4920484...
Message 3 of 8
Hi Andrew,
This issue was addressed in AutoCAD 2015 Service Pack 1. If you install it, you can then set the new system variable, CURSORBADGE to 0 to turn them off.
Victoria Studley
Content Experience Designer - Fusion 360
Fusion 360 | Learn & Support
Documentation | Contact Support
Message 4 of 8
thanks for the reply however the options im given are 1 and 2 not 0
Message 5 of 8
nestly2
You are correct... There is no "0" setting.
1 = Cursorbadges OFF
2 = Cursorbadges ON
Message 6 of 8
in reply to: Victoria.Studley
I attempted this but the option zero (0) is not available in 2015 even after the Service Pack 1 update.
Message 7 of 8
jggerth
Correct -- setting CURSORBADGES to 1 will eliminate them.
It's counter-intuitive to have a 1 and 2 setting, but no Zero, and is inconsistent with the way most Setvars in Acad work, but there you go...
Message 8 of 8
hit ctrl then right click, then click osnap settings. in dynamic input tab click off all checked.. hit ok and should be good.
”Boost
