AutoCAD Forum
How do I load an App Store application
8 REPLIES 8
Message 1 of 9
karthur1
1142 Views, 8 Replies
I am fimilar with loading app store applications into Inventor, but not with Autocad.  I downloaded the app from the app store and installed it.  In my Control Panel it shows that its installed. When I start Autocad, I do not see the new app on any of the ribbon panels. Sort-of expected to see the app on the "Add-ins" panel, but its not there.
What do I have to do to use the app that I installed?
8 REPLIES 8
Message 2 of 9
pendean
in reply to: karthur1
Did it install in another AutoCAD Profile that you have?
Which app are you trying? Which AutoCAD variant are you trying to install it to? Windows version?
Message 3 of 9
karthur1
in reply to: pendean
Using vanilla ACAD 2015, Windows 7.  Also have Autocad Mechanical 2015 and its not there either (or I just dont see it.).
I only have the one <<Vanilla>> profile.
Where will it show up?  Will it be on the Add-ins tab or someplace else?
The app is "CGSplus Selection Filters".
Message 4 of 9
Mine auomatically shows up in the Plug-Ins ribbon. If it doesn't, then the app has made a toolbar somewhere. Sometimes said toolbar shows up automatically while other times the search is on to find the toolbar.
Message 5 of 9
karthur1
Your lucky... I don't even have a "Plug-ins" tab.
Message 6 of 9
DarrenP
i guess it depends on the app
i can't seem to find this app on the exchange app store
DarrenP
Message 7 of 9
karthur1
in reply to: DarrenP
Its here.  I will load a different one and see if it shows up on the Ribbon.  It might just be a problem with this app....IDK.
Message 8 of 9
pendean
Your app is not approved for 2015 usage: see the link you posted. Contact the author for support.
Message 9 of 9
karthur1
I opened Autocad 2013 and the addin shows up on the Plug-ins tab there. So, you are correct, it is a problem with the add-in (just my luck).
Thanks.
”Boost
