I am fimilar with loading app store applications into Inventor, but not with Autocad. I downloaded the app from the app store and installed it. In my Control Panel it shows that its installed. When I start Autocad, I do not see the new app on any of the ribbon panels. Sort-of expected to see the app on the "Add-ins" panel, but its not there.
What do I have to do to use the app that I installed?
Solved by pendean. Go to Solution.
Using vanilla ACAD 2015, Windows 7. Also have Autocad Mechanical 2015 and its not there either (or I just dont see it.).
I only have the one <<Vanilla>> profile.
Where will it show up? Will it be on the Add-ins tab or someplace else?
The app is "CGSplus Selection Filters".
Mine auomatically shows up in the Plug-Ins ribbon. If it doesn't, then the app has made a toolbar somewhere. Sometimes said toolbar shows up automatically while other times the search is on to find the toolbar.
i guess it depends on the app
i can't seem to find this app on the exchange app store
DarrenP
I opened Autocad 2013 and the addin shows up on the Plug-ins tab there. So, you are correct, it is a problem with the add-in (just my luck).
Thanks.
