AutoCAD Forum
How do I create a helical pipe?
9 REPLIES 9
Message 1 of 10
jwilhite1218
867 Views, 9 Replies
I'm trying to create a pipe in the shape of a helix in AutoCAD but I haven't been able to do so.
I tried creating a helix and then I clicked create pipe and selected the helix as the line entity for pipe centerline.
If anyone could give me any tips for creating a helical pipe, I would really appreciate it.
Also, is it possible to construct lines or construction lines in the shape of a helix?
Thanks.
9 REPLIES 9
Message 2 of 10
skintsubby
in reply to: jwilhite1218
Try creating your helix, then use "SWEEP" for your pipe?
Message 3 of 10
jwilhite1218
in reply to: skintsubby
Thanks, I know what you mean, but how would I sweep the pipe? I know that I need to click "Create Pipe" and then "Select Line Entity for Pipe Centerline" and "Select Line for Pip e Cross Section Definition. But I don't see any option to sweep the pipe.
Message 4 of 10
skintsubby
Create your Helix.
Draw two concentric circles the OD and ID of your pipe
Type "SWEEP" and select the two concentric circles <right click>
Then select your helix.
Now all you have to do is subtract the internal sweep from the external sweep using the "SUBTRACT" command
Message 5 of 10
Patchy
Sweep an ARC along a helix.
Message 6 of 10
jwilhite1218
I'm sorry I'm new to AutoCAD and I've never used Subtract before. I think I got everything else except that last step when you said to subtract the internal from external sweep.
Message 7 of 10
nestly2
jwilhite1218 wrote:
.... then I clicked create pipe and selected the helix as the line entity for pipe centerline.
There's nothing like "Create Pipe" in base AutoCAD, Are you using a vertical like Civil3D, AMEP, Plant3D or a 3rd party add-on.
This his another way to do it in "AutoCAD"
Draw concentric circles and use REGION to create the profile. then SWEEP using the Helix as a path.
Message 8 of 10
skintsubby
Yes.. Just type "Subtract"
When it says "Select Objects"  pick the outside pipe. <right click>
Then pick the internal pipe. <right click>
and it will remove the internal sweep from the external sweep.
Message 9 of 10
skintsubby
in reply to: nestly2
It's not fair!!! Nestly always has nice fancy gifs!!Smiley Very Happy
Message 10 of 10
JDMather
I would have used solidedit>shell rather than 2 sweeps and subtract.
or
seems to me if you create a Region profile (Tip 2 http://home.pct.edu/~jmather/content/CAD238/AutoCAD%202007%20Tutorial%208.pdf ) of the two circles, it can be done with a single sweep.  Oops, I see Nestly already suggested that.  I guess I should read these posts.
”Boost
