I don't like them and I don't want them. I would like to have an option whether or not they display. If you are a serious draftsman or designer, this type of fluff just slows you down and time = $.
If you are a new to Acad and they are helpful to you fine. Anyone know the answer to this?
Solved by ToddRogers-WPM. Go to Solution.
Options>Display tab. Uncheck Show ToolTips and uncheck Show rollover ToolTips.
I have searching for a solution for these pesky popup windows for months. After using QSELECT to clean up a lot of old drawings, I became extremely annoyed at the window that obliterates the area I was trying to select. THANK YOU for helping. The key is trying to find the correct terminology for that stupid window. I'm glad I stumbled on the answer.
