AutoCAD Forum
HELP: Block with attributes that sum themselves
3 REPLIES 3
2424 Views, 3 Replies
Hello
It's my first time posting here (and I'm brazilian, so, if my english hurt you, I'm sorry).
I've been trying to create a block that, given three values in it's attributes lines, the fourth one would be the sum of them, automatically.
I have an sample image to ilustrate it better - if needed.
The texts "Value" and "Total" are text. The "XXX" it's the attributes. The first three must sum automatically and insert it's total in the fourth one.
Is it possible?
Thanks already for any thoughs given into it.
3 REPLIES 3
3wood
Yes you can.
1. Do not put "kg" or any units in the attributes to be added up.
2. Insert FIELD in the last attribute.
Right-click - Insert Field - Field category: Object - Objet type: click "Select Object" button to pick up the first attribut.
Select "Value" from "Property" list.
Copy the value shown in "Field Expression", it looks like %<\AcObjProp Object(%<\_ObjId 8796084697264>%).TextString>%
Paste it to your Notepad
3. Repeat Step 2 to get all 3 attribute field expression.
4. Back to Field dialogue, Select "Formula" from "Field category", copy and paste 3 attribute field expressions into the Formula area, add "+" in between values. The field expresstion will change into figures automacitally as "100", "10", etc. The formula looks like "100+10+1".
5. Click OK in the Field dialogue.
in reply to: 3wood
Mr. 3wood, first of all: Thanks A LOT.
But still I'm not being able to use it as I want.
I did follow your steps and worked fine, but only with the default value.
When I edit this value after inserting the block in the drawing, the formula stops working and the total line do not update itself.
When I try to leave de default line blank or with a "---" it also doesn't work. hm
Could you help me a further more? 😧
3wood
You need REGEN to update the field value.
Please also try my example drawing in the attachment.
”Boost
