Hi everyone,
I am struggling to find a way to have an attribute block in wich i write a value (i.e. 1000mm) and by his side automatically it appears the corrispondent inches value.
I enclose the block to help you understand what i need!
thank you in advance
Sandrapane Hi,
Attached MM2IN.zip contains MM2IN.vlx is a little lisp program that will do what you want
extract the vlx file then load it in your dwg then invoke mm2in command
cheers
Moshe
Sorry forgot to post your dwg file back which contains your modified block
i added a second attribute call INCH (with out it the lisp won't work)
hi,
first thank you very much for your help, it works greatly on your block, but when i try it on mine it doesn't even get the selection, i don't understand why
Thanks again
Lucy
@sandrapane wrote:hi,
Thanks again
Lucy
What do you mean by 'Your Block'? it is totaly your block by the name 'QUOTA'
the lisp is designed to work only with 'QUOTA' blocks and it should contains two attributes tag names '+QUOTA' and 'INCH'
any other block names or attributes tag is ignore
Moshe
Ok now i get it! I tought it would work on every block, thanks again!
Lucy
