I'm trying to hatch an object with a transparent background. On the screen it looks fine but when I print it the background is always solid/opaque no matter what color or transparency setting I use. Is there another setting I'm missing?
Hello from France
When you print/plot : you have a NEW option (since transparency and version 2011) in the dialog box settings (print/plot)
on the RIGHT panel : please enable/activate the plot WITH Transparency !
Bye, Pat
Patrice BRAUD
What setting(s) have you already tried?
The transparency level for new hatch objects is controlled by the HPTRANSPARENCY system variable. (0 to 90, with 90 being most transparent). Changing the value does not affect existing hatch objects.
The TRANSPARENCYDISPLAY system variable controls whether object transparency is displayed.
In Properties, is the Background color property set to "none"? Is Transparency set to Bylayer?
I also don't use transparency, so I hadn't taken notice of that Plot setting either. We both learned something today.
