I have been building a bush cross section.
I am building it as a dynamic block as I need copies in many different sizes.
Due to the cross section I am using hatches to indicate different materials (only 2)
When I change some distances linked to actions the hatch remains inside its boundary and conforms to the new shape, most of the grips work perfectly whereas one, the top left grip, misbehaves time after time and breaks the hatch associativity.
Does anyone have an idea why this is?
I should mention that I had it working perfectly earlier, but was asked to add a fillet onto my drawing and after putting this in and tweaking everything I have no longer been able to reach perfection.
THanks in advance
It is I believe as when the boundary changes the majoritory of the time the hatch changes, except in a few special cases.
To create the hatch I used the "Pick point" inside a boundary option. I belive this makes it automagically associative as all my past blocks created in the same way have not had this problem, it is just the inclusion of the arcs as fillets which have thrown a spanner in the works.
I have solved the issue. For now.
I changed some of the stretched objects.
Here is a file with the broken object on the left and the fixed on the right.
thank you
There's a lot going on in your block, but two suggestions are:
1) Use 4 hatches, rather than 1, and make them each associative.
2) After you add the fillets and modify the hatches, you have to redo the stretch frames to include the modified objects.
