I've never had this happen before I started at my new job. I am doing a hatch around some windows that are made up of multiple lines (not on top of each other but showing the frame) When I fill the hatch for siding around the outside it will fill in the inside of the window frame sometimes. All of the lines are connect so that isn't why.
The weirdest part is that when the hatch is set to solid it doesn't do it. when it is set to the siding hatch then it does it.
i've attached a pdf. The first page shows the hatch boundaries and the second where the hatch is showing up where its not supposed. I can fix it by removing the hatch boarder inside but i thought maybe there was a better way so I dont have to do it each time.
Solved by arkman. Go to Solution.
Solved by pendean. Go to Solution.
Actually i think I got it. I found the little arrow to pop out the dialog box. In there I changed the island detection from normal to outer and it seems to have worked.
