AutoCAD Forum
Grips
8 REPLIES 8
Message 1 of 9
blowout
576 Views, 8 Replies
Grips
I am running AutoCAD 2014.  When I select any random object, (line, circle, block, etc.), to activate grips, the grips will go away (deselect) if I pan or scroll to grab more objects. This didn’t happen in the past. Is there a setting that I may have inadvertently changed?
8 REPLIES 8
Message 2 of 9
nestly2
in reply to: blowout
I've never been able to recreate this issue myself, but there seems to be an issue where dense/corrupt hatches can cause what you've described.  If you have hatches in the drawing, try deleting them, or turning off their layer and see if that fixes the pan/deselect issue.  If so, you may have to re-create the hatches to "solve" the problem.
Message 3 of 9
blowout
in reply to: nestly2
Thanks nestly2! i'll try the suggestion, but i dont recall the issue being limited to Darwings with hatches.
Message 4 of 9
nestly2
You might also check to see if it happens in MS, or only in a Layout/Viewport.
Message 5 of 9
KLYPHY
I checked my AutoCAD Notes and found this entry:
GRIPS: DISAPPEARING: 080314FR:
If the Grips disappear while selecting a number of objects, use GRIPOBJLIMIT to set the maximum number of grips permitted.
From AutoCAD Discussion Groups:C O Jones: Mar/13/08 - 21:11(GMT) in “Selecting more then 50 objects and I lose GRIPS” by: cadanator: Mar/13/08 - 20:51(GMT)
Message 6 of 9
blowout
in reply to: KLYPHY
Just rest the GRIPOBJLIMIT. it was defaulted to 50. Will test the new setting and reply back. Thanks for the suggestion!!
Message 7 of 9
Shawn_Niles
Did the GRIPOBJLIMIT setting help to resolve this?
Shawn Niles
Message 8 of 9
blowout
in reply to: Shawn_Niles
So far so good!!! the real test will come down the road a bit, but thanks as usual!
Message 9 of 9
KLYPHY
in reply to: KLYPHY
I keep my own AutoCAD notes, gathering info from many different sites.
I always keep record of who wrote what, where, and when.
This info appears at the bottom of each note.
The answer I was quoting was frp, tje AutoCAD Discussion Groups and was written by C.O.Jones, March 13, 2008 at 21:11(GMT).
He was responding to a post "Selection more tha 50 objects and I lose GRIPS", written by cadanator
on Mar 13, 2008 at 20:51(GMT).
I like to give credit to those who solve our problems.
”Boost
