hello everyone,
I've installed Autocad 2015 and I'm having a serious problems and I diden't face these problems in 2014 or 2013 versions
1 - my GUI is different than the one in this video https://www.youtube.com/watch?v=WmUhPX0Z7pM
2 - when I turn hardware acceleration on, I my screen be like this
and when I turn hardware acceleration off the cursor keep flashing
My hardware specifications
intel core i7 2.2 ghz
8 Gb RAM
nvidia 525m with vram 1GB
Solved by chenchri. Go to Solution.
Please try to draw a leader using QLEADER.
Can you see the lines before you end the command?
Thank you.
update the nVidia driver, I had a similar problem when turning on hw-acceleration the whole graphic area flickered with every mouse move.
Since the driver update everything works fine.
- alfred -
don't see your video card on the reccommended or certified list for 2014. Don't know that it would be either for 2015...
Have you tried turning on Hardware Acceleration but with Line Smoothing turned off?
This so called "reccommended or certified list" it's a big hoax.
On my computer the video card Quadro 4000 is not certified for 2014 and it's working perfectly.
If I use 2015, the card is reported as certified but is working very poor (bad hatch selection, non smooth mouse movements, mouse leaving trails, leader not displayed until command end ...).
Hello from France
YES unfortunately Autodesk has changed something in its 2015 graphic interface to the graphic card driver !
So a graphic card running well with 2014/2013, can have strange problem with 2015 !
1) Disabling the Hardware Graphic Acceleration mostly solve the problem/bug but ACAD is slow ...
2) Try LINESMOOTHING = 0 - Could solve the problem but I don't think so ...
Please follow this Topic :
http://forums.autodesk.com/t5/AutoCAD-2013-2014-2015/AutoCAD-2015-27-unfixed-bugs/td-p/4916232
Patrice BRAUD
w64bit:
Where did you find a list of "certified" cards for 2015? I've only been able to find this on the Autodesk website, which only goes up to 2014 right now:
http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534
If I could reference an Autodesk list saying my card was certified, I could then fill out a subscription support ticket.
The Certified Hardware page has been updated for 2015.
My certified card is not fully working as indicated. Also, the certified driver they list is currently shown as a beta driver from 2013 on the AMD website. The latest AMD drivers did not work for me. I've submitted a support ticket.
>> but none of the suggested solutions worked with me
Really .. even disabling the hw-acceleration does not help, shows the same flickering?
- alfred -
Hello
If you have a NVidia graphic card : have you tried to DISABLE the "NVidia Anti-Aliasing FXAA" Feature ?
Does it help ?
Patrice BRAUD
I have exactly the same problem as you, and none of the above solutions solve my problem!
The only solution for me is to disable hardware acceleration!
Until there's a solution that I'm going to switch back to version 2014 ....
(sorry for my crappy English)
w64bit:
When you select a suite, then 2015 is not available.
If you select AutoCAD, then 2015 is available.
I installed the nvidia beta drivers v 337.50, and everything seems to run fine now.
GTX 760M
i7 4702MQ
12GB RAM
Hi! I wolud really like to test the beta hotfitx. I'm trying to evaluate version 2015, but the graphics problem its a major trade off, turning off hardware acceleration its awfully slow. Thanks
I think my problem is related to this thread so I will post it here.
I installed autodesk product design suit premium 2015, Checked out inventor since that is where a majority of my work is done and it worked fine.
opened autocad and soon learned that the cursor was screwey, no crosshairs, just a arrow cursor when in the model space, and it didnt work, if I selected line and tried to click a starting point it continued to ask for a starting point, then I went to the command line and found that when I typed nothing was entered, but when I hit the enter key it returned like I would if it was a blank line.
So I opened acad 2014 and thought I could work but suddenly have the same issues there (It worked fin right before installing 2015). I uninstalled autocad 2015, ran repair on 2014, still no good. I also find that some buttons do not react to the mouse action, for instance I go to polar tracking and it lights up when I hover over it, but nothing happens when I click it, it should toggle on or off, but right next to it is 2d object snap and it works fine.
running W7-64 on a dell precision notebook, I updated the nVidia drivers to the latest (332.76), I tried resetting my profile by going to another one and then comming back, It didnt work in either profile.
hardware acceleration is off, but that is one of the buttons that doesnt respond so I cant find a way to run performance tuner, or see if it would work with HW performance on.
Any ideas of what to try next would be appreciated.
Just a bit of an update:
I uninstalled product design suite 2015 (all of it) and things still not working, so I did a system restore to right before I initially installed product design suite and got 2014 back to working.
I guess I should wait a month or two until they have a service pack with some fixes before installing a new product, Does Acad even beta test?
