I am having trouble with the graphics in my layouts tabs. When I select the layout tab, I cannot move the drawing with my right mouse button, nor can I select the viewport. The wierdest thing is that when I move my mouse (without clicking or giving any commands) the image changes. I have attached some screenshots so you can see what I'm trying to describe. This problem started suddenly, and occurs on new, old, and blank drawing files.
Solved by benedictos.virgilio. Go to Solution.
hello sir,
I think your problem is your hardware, try to check/update or uprade you memory card and video card.. its either low memory or low resolution or maybe its not updated or compatible...
hope this will help..
regards
Virgilio Benedictos
Hi There,
First of all Welcome to the community.
Just a few questions: Do you have all the latest service packs installed for your AutoCAD? Do you have the lastest Graphics drivers installed?
Hello
A few questions :
Q1) Which version of AutoCAD ?
Q2) 32 or 64 bits ?
Q3) Which Windows exactly ?
Q4) Which graphic card ?
Bye, Pat
Patrice BRAUD
