To test GPU I did the following:
- Run AutoCAD
- Entered the command “appload” and load “GsTest.arx”
- Load DWG file: Civil3D TestFile.dwg - 13Mb
- Run test: “GSTESTBENCHMARK”
I got the following results:
HP e230 i7 4770 16Gb Intel HD Graphics 4600:
Wireframe : 246325.391337 ms
Wireframe : 0.738860 fps
Hidden Line : 303961.642595 ms
Hidden Line : 0.598760 fps
Flat Shaded : 284280.566670 ms
Flat Shaded : 0.640213 fps
Gouraud Shaded : 277416.793930 ms
Gouraud Shaded : 0.656053 fps
HP e230 i7 4770 16Gb Quadro K2000 :
Wireframe : 258924.592965 ms
Wireframe : 0.702907 fps
Hidden Line : 312113.675504 ms
Hidden Line : 0.583121 fps
Flat Shaded : 295053.300128 ms
Flat Shaded : 0.616838 fps
Gouraud Shaded : 295865.243346 ms
Gouraud Shaded : 0.615145 fps
The performance of Intel HD Graphics 4600 is equal to Quadro K2000 ?
Core i5 3230M HD4000 (integrated) 16Gb ram (HP laptop)
Wireframe : 684965.128121 ms
Wireframe : 0.265707 fps
Hidden Line : 764249.351067 ms
Hidden Line : 0.238142 fps
Flat Shaded : 645534.715567 ms
Flat Shaded : 0.281937 fps
Gouraud Shaded : 643812.359181 ms
Gouraud Shaded : 0.282691 fps
I´m trying to figure out what new laptop to get for work (AutoCAD Plant 3D, pipes) Should I opt for a Quadro with 2Gb dedicated memory or settle for some gaming GPU like GTX860m or GTX970m? Is it worth $500 more for the Quadro?
CPU wise I figured I should focus on single core performance since AutoCAD cant use more than one thread (unless you use som plugin) so a high clock i7 should do the trick?
Cheers!
