AutoCAD Forum
Get the object (or handle) of new objects created using WBlockCloneObjects
4 REPLIES 4
michael.robertson
293 Views, 4 Replies
I created new entities in a file using WBlockCloneObjects from a different file.
I have a collection of objectids from the source file.
Once I pass this collection to the WBlockCloneOjbects is there a way to get to the objectids (or handles) of the objects cloned into the new file? I need to change the layer on each new object.
Thanks in advance,
Mike
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
4 REPLIES 4
If you are wanting to change them all to the same layer (whatever that layer might be) you can trap them all in a selection set. To do this, set the last entity as a marker, proceed with the wblock, cycle through the new entities to create your selection set, and then do what you want with them.
(setq Marker (entlast))
;wblock, copy, or whatever here
(setq tempSS (ssadd))
(while (setq Marker (entnext Marker))
(setq tempSS (ssadd Marker tempSS))
(command ".chprop" tempSS "" "layer" "whateverlayer" "")
Sorry for posting in the wrong forum.
I was thinking I would have to do something like you suggest.
I'll give that a try.
Mike Robertson
Found I could use the "GetAllObjects" method of the current TransactionManager to retrieve these objects.
Mike Robertson
”Boost
