After installing the VBA Module, I get the message "Unknown command "VBARUN"". I've rebooted, restarted and tried reinstalling the VBA Module to no avail. Any suggestions.
George Flew
Solved by gflew. Go to Solution.
What module did you install? Please show the exact link!
What AutoCAD version do you have? And if it's a vertical product, which one is it.
What operating system do you have?
- alfred -
Alfred, thanks for replying. Here is the info you asked for.
1. I installed the 2014 VBA module 64-bit from the S&S download sight http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=12715668&linkID=9240618
2. The error was from ACAD Electric 2014 SP1.1 (64bit)
3. I'm running Win 7 Enterprise (64bit)
Oddly, I get the message _vbaload Unknown command "VBALOAD" when I initially start the program. However, when I run appload, I can load the dvb file and all runs fine thereafter, even the _vbaload command.
While this solves the immediate problem, I'm concerned about some underlying problem that might raise it's head later.
Again thanks,
George
What happens if you start the command with a dot:
_.VBALOAD
Also an option (for trial, not forever): set the sysvar DEMANDLOAD to 0 and try it again (after restarting AutoCAD.
- alfred -
Alfred, unfortunately, neither suggestion seemed to make any difference. I have now added the VBA project to the Startup Suite and it loads automatically. Once loaded the vba commands works correctly.
Thanks for the assistance.
George
