Dear Autodesk,
Can someone fix this bug please
Please see screen shot
Im not able to use Geolocation maps in Autocad after updating the arx file.
They ask for credentials for Bing map
Does this means we now also need to make an extra account at bing?
Regards
Don
Do you have an A360 Account? Did you reboot your AutoCAD and workstation after applying the fix? If yes to both of those sign out of A360 from the windows task bar/apps and retry in AutoCAD to connect.
Did what you said and now i cant connect to maps at all
It says im offline and im logged in so its a big fail
Cant use it anymore
See screenshot
This is how it looks after the update
I did restart and logged out multiple times to try
Bud its not working anymore
How can we solve this?
Is this an network issue?
Firewall issue?
Program issue?
If you need more info please let me know
I have Plant design suite premium 2014
Also have 360
Regards
Don
Thanks in advance
Hi Don,
Please check this document, it contains the most common issues when connecting to Bing Maps:
Please check the proxy and firewall settings.
I hope this helps
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Hi Don,
Please check this document, it contains the most common issues and solutions when connecting to Bing Maps:
I hope this helps
Hi Albert,
Thanks for your reply.
I showed IT dep a part od the docs for them so they can see if some settings are correct.
The rest is how it should be
Think its an Network issue.
Regards
Don
