Here's one.see if you get the same result.
This is for users still using "Classic Autcad Tool bars" (Yes I'm still using them !)
Start a drawing new or exisitng that has a block.
single click on block........start Block Editor
Make any kind of change.
Then click "Exit Block editor"
Select "Save Changes"
Once this is done..............the Block editor "Tool bar across the top remains in place
It's not selectable,
Running with "Hardware Accelaration "ON"
Let me know if anyone sees this !
Ron
Same results with "Hardware Accelaration" OFF
Specs:
Windows 7 Enterprise 64bit OS
i5 3.20 Ghz
6 gigs Mem.
AMD FirePro V3900
AutoCad 2015 64bit
Ron
Ron:
I had a problem similar to this back in AutoCAD 2012. Is this what is happening for you?
http://forums.autodesk.com/t5/AutoCAD-2010-2011-2012/Redundant-Block-Editor-Toolbars/td-p/3021222
Unfortunately, the only fix for that for me was through a Service Pack.
I am not experiencing this issue with 2015. I have the Ribbon turned off and one custom toolbar outside of the drawing area. I have Hardware Acceleration on but Line Smoothing turned off.
This behavior was reported to us during the Beta program for AutoCAD 2015 so our developers are definitely aware of it.
On my system here, oddly, I can get it to happen in LT 2015, but not full AutoCAD 2015.
I found that turning any docked toolbar on or off, undocking a docked toolbar, or docking a floating toolbar will make the ghost Block Editor toolbar go away. Also, toggling between workspaces will turn it off.
is there any answer to this problem ? , I am having a similar issue with a client that I am supporting , Did SP1 solve this issue for 2015 ?
