So this problem is a result of a workaround for this problem here:
Can someone tell me why AutoCAD insists on putting the "mm" suffix on angular dimensions??? It looks stupid and unprofessional. The only way I know how to fix it right now is manually edit each angular dimension. Is there abetter way?
Please note: I need the "mm" unit label on linear dimensions because I am dimensioing in dual dimensions for drawings being reviewed by customers here in the states but manufactured by suppliers in Europe.
It is frustrating that AutoCAD will not allow me to draw in metric units in a metric template but dimension in IMPERIAL primary units and METRIC secondary units (see here for that discussion: Dimension Scaling Problem)
Thanks to anyone that can help me solve this.
Solved by nestly2. Go to Solution.
You need to create a "child" dimension style so Linear dimensions get the mm suffix, but not angular dimension. I made a video of this some years ago, but the site I have it hosted on seems to be down at the moment....
If you can't figure out how to create a child dimstyle, post back and I'll try again to retrieve the link to the demo.
Here's a link to the demo... .I believe it shows exactly how to correct the scenario you described
Create a child dimstyle - Linear --> http://www.screencast.com/t/DcIbkbkUmu
