Hello All,
I have a simple table that I am putting dimensions into. Client standards dictate stacked fractions. When inputting into table I can stack them and as soon I click outside the cell it reverts back to the unstacked form. If I create an mtext it will stack. Dimension style is set for stacked and I have tried enabling autostacking as well.
Any ideas?
Thanks in advance,
Dan
Solved by daniel.klingspor. Go to Solution.
I've noticed that line spacing changes when stacking fractions in mtext. It could be that the cell size of your table forcing the unstacking as the stacked version is too big for the cell. Maybe try to enlarge the borders of your cell and see if will stack?
Thanks for the reply,
This did not affect the fractions in this instance. The problem ended up being the data format in the table itself. When set to "decimal number, architectural" it was causing the problem. Changing the format to "text" corrected the issue.
Thanks again,
Dan
