I use autoCAD mostly to do as-built 2D drawings of conduit routing over architectural backgrounds. But, I have been asked to do a shop drawing in 3D which needs to include 1/2" and 3/4" flexible steel conduit.
I've updated my subscription (single seat user) each year from 2009. And, I have the latest 2015 installed on my computer. But, I'm still doing everything in 2011 since I'm used to that UI. Only use 2015 to open and back save drawings to 2010.
At present, I've built a 3D representation of a piece of mechanical equipment (done in 2011). And, I can extrude paths to represent smooth conduit (which is my next task).
But, is there a routine without upgrading to MEP or buying a 3rd party software package to build a 3D representation of flexible conduit (steel flex) in AutoCAD?
Thank you,
Chris Simmons
Solved by dbroad. Go to Solution.
Try sweeping a circle on a polyline or 3dpoly path (or combination of them if you have multiple planes since polylines are limited to single planes). polylines and splines support curved paths but 3dpolys only have straight segments.
