I have been working on this project for awhile, trying to get it to extrude. The top drawing of the shape is when I created it, still as lines and arcs. The bottom pices are what I have broken it into and joined as polylines for extrusion. The top most piece of these is the one I have been working with, with no solution found. The 3 smallest of these pieces do extrude, but I need all of them to extrude as they are all different heights, and I am just too frustrated now to do this anymore even though I need it ready in 7 hours. Once this extrusion problem is solved, the rest is just unioning it together and to the rest of my project. I have tried exploding them, overkilling them and joining them again, I have tried the boundary method I have found on forums, nothing is working. I have gone through with a fine tooth comb on the top most section and made sure there wasn't anything extra. I have tried using pedit on it, and many of the commands say you can't do this on a closed polyline. If its a closed polyline, why won't it extrude? I could find anywere where it was "Self intersecting curves" like the error says when I try to extrude it. Help is greatly appreciated.
Solved by Alfred.NESWADBA. Go to Solution.
You can find or you can not find the positions ... check those samples of self-intersections:
If you check these positions, don't forget to _REGEN when you zoom close to the vertices, then the rounding of the arcs are refreshed.
- alfred -
Ok, so that does not help so much. Again, the only piece I have been working on is the large top piece, which I will attach to this message. The other pieces I haven't even looked at so yes, I know they still may have overlaps on them. I am wondering why this piece won't extrude. I have spent hours going over it, I thought I had every overlap and problem fixed, yet it still won't. I found one more, it still won't extrude but no error messages come up when I try to extrude it. Lets focus on this piece this time, if there is a solution to this one, then I can fix the rest.
I didn't readily notice the problem with your polyline, but the BOUNDARY command (aka BPOLY) will create a new polyline boundary that may be extruded without any error messages. Similarly, using PRESSPULL rather than EXTRUDE will "extrude" your original polyline into a 3D Solid.
I get the message during selection:
Cannot sweep or extrude a self-intersecting curve.
1 object removed from selection set.
And yes, it's very hard to find. I first switched to visual style 2D-Wireframe, I also disabled the hardware acceleration as (at least with my gc-driver) I have troubles when zooming into very deep detail, and last but not least I scaled the objects with factor 1000. At least that position shows some strange mini-gap between the polyline-arcs, so I guess it's to close for extrusion, to close for mathematical accuracy.
And good to have nestly 😉 both suggestions work well (naturally).
- alfred -
