One of the common things we need to do at my company is export a PDF of a drawing via the DWG To PDF.pc3 Plotter.
It takes us a long time to sort through all the available sizes for this plotter, so we wanted to filter it out. Here is the problem we're encountering:
We can't set the default size to the one we want because it always changes it back to "ISO full bleed B1 (707.00 x 1000.00 MM)" regardless of what I do.
Even if I try to filter it out, it's the only one out of all the options that refuses to stay unchecked.
I've already tried modifying the plotter to do what i want and it doesn't work.
How can I fix this problem so that I only have these two paper sizes that appear in the drop down menu:
ANSI full bleed B (11.00 x 17.00 Inches)
ANSI full bleed A (8.50 x 11.00 Inches)
I also want it to default to 11x17.
Thank you!
I know this does not answer the question, but have you tried the EXPORTPDF command? It will attempt to use the current pagesetup settings.
To get back to your question, I see a similar issue here (B1 is always visible), but it's not always the default unless there is not a page size equal to the page size in the current page setup.
Start using named page setups, & that will greatly simlify your life, Just chose the pagesetup when plotting or publishing, and no need to worry about hpw many different page sizes are theoretically available from that plotter -- you've already defined the few you need.
