AutoCAD 2013/2014/2015
juliewaddell1075
Message 1 of 10 (6,023 Views)
Accepted Solution
File Path Location for Blocks
6023 Views, 9 Replies
02-26-2013 08:43 AM
Looking for a reference that shows what the default file path locations are for various AutoCAD  user files.  Specifically, I had my AutoCAD file paths changed and cannot find where my blocks are saved.  I'd like to save the blocks I create in a specific folder.  I'd sure appreciate your feedback.  Julie
Sincerely,
JamJaws31
Can't find your blocks anywhere?
 WBLOCK instead of BLOCK ?
Thanks. Must have got my BLOCK and WBLOCK mixed up? When I used WBLOCK I was able to find the block in the folder I want the blocks I create (for use outside the current drawing) to go to.
:smileyhappy:  This is the immediate solution to my problem.  Still want to know where the blocks for the "BLOCK" command are stored, but I am able to access the blocks when using the "WBLOCK" command.  Thank you.  This has resolved this issue, but would like further discussion.  Julie
*Expert Elite*
Patchy
Message 2 of 10 (6,008 Views)
Re: File Path Location for Blocks
02-26-2013 09:05 AM in reply to: juliewaddell1075
"I had my AutoCAD file paths changed and cannot find where my blocks are saved"
Block = .dwg
You know the name of the blocks?  Use ADCENTER or Windows search, it's not that difficult.
*Expert Elite*
dbroad
Message 3 of 10 (5,999 Views)
02-26-2013 09:30 AM in reply to: juliewaddell1075
If other things aren't working as well, a repair install should fix the built-in profiles.
*Expert Elite*
M_Hensley
Message 4 of 10 (5,981 Views)
02-26-2013 11:16 AM in reply to: juliewaddell1075
Under Tools, Options select the Files tab and highlight Support File Search Path. Pick the Add button then Browse and navigate to where your block drawings are located.
juliewaddell1075
Message 5 of 10 (5,975 Views)
02-26-2013 11:46 AM in reply to: M_Hensley
Thanks for your reply I followed your instructions and did not find the temporary block I created in the folder, nor was I able to insert the temporary block I created using the browse function to the folder where the path points to. I previously did a Windows Explorer search and was not able to find the first block I created when I originally posted this issue.
Sincerely,
JamJaws31
*Expert Elite*
Patchy
Message 6 of 10 (5,967 Views)
02-26-2013 12:20 PM in reply to: juliewaddell1075
juliewaddell1075
Message 7 of 10 (5,963 Views)
02-26-2013 12:51 PM in reply to: Patchy
Sincerely,
JamJaws31
juliewaddell1075
Message 8 of 10 (5,933 Views)
02-28-2013 09:11 AM in reply to: juliewaddell1075
Sincerely,
JamJaws31
*Expert Elite*
Patchy
Message 9 of 10 (5,922 Views)
02-28-2013 09:19 AM in reply to: juliewaddell1075
Let's clear this mud for you.
Block command write the block to the drawing
Wblock command doesn't access for you to pull the block from anywhere, it writes to the folder you choose.
juliewaddell1075
Message 10 of 10 (5,920 Views)
02-28-2013 09:24 AM in reply to: Patchy
Thank you. I had the access the block from the folder down, but was confused this was associated with the WBLOCK rather the the BLOCK command. Appreciate the clarification! [?]
Sincerely,
JamJaws31
Post to the Community
New Post
Need installation help?
