Hi.
As a default field LOGIN dispaly my full name and surname - I would like to modify it to display only my initial - is it possible in AC LT 2015?
Regards...
Solved by cessares. Go to Solution.
I suppose you could use a diesel expression. You'll have to modify this to work for you.
$(substr,$(getvar,loginname),1,1)$(substr,$(getvar,loginname),6,1)
My first name is 5 characters long so the 6,1 gets the first initial of my last name.
Hi. How do I use this diesel expression - never heared it? Does it work in LT?
When writing text right-click and select Insert Field. Under Field names select DieselExpression. Paste the diesel code in the box on the right.
Thanks for that....but - see picture 😕
Where can I find dieles expressions? I think I can make use of them in the future...
I don't have LT to test, but what happens if you just type in Loginname at the command line?
Command: LOginname
Unknown command "LOGINNAME". Press F1 for help.
Fck! 🙂
I'm out of ideas on that. Someone with more LT knowledge will have to chime in.
No option for login 😕
LT is LT
Diesel works on file name, I can extract what I want from it - how to dispaly CAPITAL LETTERS insted lowercases?
