AutoCAD Forum
Field LOGIN - can I change content of it...?
10 REPLIES 10
Message 1 of 11
cessares
1529 Views, 10 Replies
Hi.
As a default field LOGIN dispaly my full name and surname - I would like to modify it to display only my initial - is it possible in AC LT 2015?
Regards...
10 REPLIES 10
Message 2 of 11
Jason.Piercey
in reply to: cessares
I suppose you could use a diesel expression.  You'll have to modify this to work for you.
$(substr,$(getvar,loginname),1,1)$(substr,$(getvar,loginname),6,1)
My first name is 5 characters long so the 6,1 gets the first initial of my last name.
Message 3 of 11
cessares
in reply to: Jason.Piercey
Hi. How do I use this diesel expression - never heared it? Does it work in LT?
Message 4 of 11
M_Hensley
When writing text right-click and select Insert Field. Under Field names select DieselExpression. Paste the diesel code in the box on the right.
Message 5 of 11
Jason.Piercey
@cessares wrote:
Does it work in LT?
Yes.
Message 6 of 11
cessares
Thanks for that....but - see picture 😕
Where can I find dieles expressions? I think I can make use of them in the future...
Message 7 of 11
Jason.Piercey
I don't have LT to test, but what happens if you just type in Loginname at the command line?
Message 8 of 11
cessares
Command: LOginname
Unknown command "LOGINNAME". Press F1 for help.
Fck! 🙂
Message 9 of 11
Jason.Piercey
I'm out of ideas on that.  Someone with more LT knowledge will have to chime in.
Message 10 of 11
cessares
No option for login 😕
LT is LT
Diesel works on file name, I can extract what I want from it - how to dispaly CAPITAL LETTERS insted lowercases?
Message 11 of 11
Jason.Piercey
You can use the UPPER function in the diesel expression.  Check the help files for proper syntax.
”Boost
