first of all, copy your BAK file away, it might be your last release you can open.
With your DWG, in case you are working in a network environment:
Also helpful in case of XRef's ==> make sure that the referenced DWG-files can't be found as it might be possible that not your "master drawing" has that issue, just one of the XRef's.
You might also try to create a new drawing and start command _INSERT to import the content of the defect drawing.
If you have Map 3D (or Civil 3D) you might try the ADEDRAWINGS ==> ADEQUERY approach to get data imported from the problem-DWG.
At least you might upload your DWG file, maybe someone here get the drawing back to life.
Good luck, - alfred -
If I run _REVOVER or _RECOVERALL it still crashes. I can insert it into a new drawing, but it has no layout or title block information.
Try to use design-center, it has the option to drag & drop a ylout from one drawing to your current one.
- alfred -
