i get that error.
FATAL ERROR: Unhandled Access Violation Reading 0xffffffff Exception at 759baa0fh
twice time today when i draw.
any help?
My PC Information:
I used Autocad 2015 SP2
VGA: Nvidia GT 430 Driver Version: 344.11 (Latest Driver)
OS:Windows 8.1 Enterprise
Memory: 4GB Ram (4.00 GB Usable)
CPU:Intel Core 2 Quad Q8200 @ 2.33GHZ
Solved by braudpat. Go to Solution.
Hello
Welcome to the Autodesk/AutoCAD Forums !
Q1) Have you tried to open your DWG in RECOVER Mode, maybe PURGE it, ReSave, Quit, ReLoad, Test ...
Q2) THEN - Have you the problem with the DWG on the Network ?
If YES, please try to save it on your Local hard disk, ReLoad from Local hard disk, Test ...
The SP2 for 2015, is not "very good" so you can try to Un-Install it ...
Patrice BRAUD
