AutoCAD Forum
FATAL ERROR unhandled access violation reading
11 REPLIES 11
Message 1 of 12
3635 Views, 11 Replies
hey,
so i've been getting this pop up window everytime i try to open autocad today. yesterday night i was using it fine.
now whenever i try to open the program, it says "fatal error unhandled access violation reading b14c4b12h"
i sent an error report to autodesk and they suggested a patch. and after restarting my pc its still not working.
i have win8.1 with autocad2014.
it pisses me off koz i have school assignments to do and it's not working 😞
Thanks for your help.
11 REPLIES 11
Message 2 of 12
Alfred.NESWADBA
SCNR: but you had time to install Win 8.1, an OS that is not supported with AutoCAD 2014 (yet).
If AutoCAD was running ever with 8.1 then look what updates Windows has installed from yesterday to today and uninstall them.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 3 of 12
in reply to: Alfred.NESWADBA
i didnt know it was not compatible. so up till now there is no solution to that problem?
Message 4 of 12
Alfred.NESWADBA
I don't know anyone running AutoCAD 2014 on Win8,1 ... but I read some info's about troubles with Win 8.1
So the question again is, what changed from yesterday to today on your system?
Was it the update from Win8 to 8.1 (or was the update to 8.1 earlier and AutoCAD did run with that)?
...or any other (Windows internal) updates?
...or any software installed?
- alfred -
Alfred NESWADBA
Message 5 of 12
i did restart my pc this morning and it did automatic updates
im attaching a picture of the recent updates. it has to be the ones from today because it was working perfectly fine yesterday or the days before.
Message 6 of 12
Alfred.NESWADBA
as the display driver was updated you might try to start AutoCAD without hardware acceleration, see the startup parameters therefor >>>click<<<, use the /nohardware parameter and try to start AutoCAD with that.
If that does not help uninstall the last two updates (or the last three ones), disable automatic updates, restart Windows and try then AutoCAD.
- alfred -
Alfred NESWADBA
Message 7 of 12
i tried to unistall the updates but its still not working... and i also tried with nohardware, but it's still not working?? is there any version of autocad that will work??
Message 8 of 12
i already tried with my previous versions of 2011 and 2010 but it doesnt work
Message 9 of 12
Alfred.NESWADBA
Again the question: you had AutoCAD running free of errors on Win8.1?
For now I don't know any offical statement from Autodesk about what applications are supported for Win 8.1 and which are not. For AutoCAD only release 2014 (and 2013 with service pack 2) are tested with Windows 8 (not 8.1).
So the only real chance I see is to wait for servicepacks or reinstall Windows 8 without the update to 8.1
- alfred -
Alfred NESWADBA
Message 10 of 12
Alfred.NESWADBA
one additional idea: create a new user for your Windows (with admin permissions), login with that new account and try AutoCAD to start.
- alfred -
Alfred NESWADBA
Message 11 of 12
tried. still not working. 😞  i'll wait for a patch from autodesk i guess. i hope it get solved quickly.
thanks for your help 🙂
Message 12 of 12
drprintergt
In case you have not resolved this issue yet....
Update the video card driver from the manufactures support website, I just did it and after that, Autocad 2014 worked fine under windows 8.1
”Boost
