¿1. ocurre con cada dibujo que intenta abrir?
¿2. ocurre a cualquier otro usuario abrir los mismos dibujos?
¿3. si copia a su computadora, abrirá normalmente el programa?
Esto podría eliminar si el problema es con ella o con la red.
Si no funciona nada más, te recomiendo una instalación de reparación.
1. Does this happen with every drawing she tries to open?
2. Does this happen to any other users opening the same drawings?
3. If copied to her computer, will the program open normally?
This might eliminate whether the problem is with her or the network.
If nothing else works, I recommend a REPAIR installation.
The suggestions might help:
Las sugerencias pueden ayudar:
http://forums.augi.com/forumdisplay.php?860-Foros-Españolhttp://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Fatal-Error/td-p/4697727http://forums.autodesk.com/t5/AutoCAD-2013-2014-2015/fatal-error-opening-drawing-from-network-share/..."""A:Good afternoon happens to one of my users it is presenting the following drawback, all Autocad files which they work are the network, a server occasionally she is working and appears this error, you must restart.
Someone could tell me why?
This autocad does not have additional plug-ins.
THANK YOU SO MUCH!"""
Melanie Stone
Facilities Data Management
IWMS / CAFM / CMMS / AutoCAD / Archibus / Tririga / Planon / MRI Manhattan CenterStone / Revit / data normalization, data mapping, reporting and process documentation
mistressofthedorkness.blogspot.com/
