I have an xref visible in my drawing. This exref has about 30 layers. I want to know if there is a way of turning the entire xref of so I can edit my current drawing and then turn the entire xref back on. It needs to be a quick command like layof and layon
Regards Tony
Solved by rkmcswain. Go to Solution.
Solved by M_Hensley. Go to Solution.
Solved by 3wood. Go to Solution.
there is 2 way for that :
1- xref filter layers from Layer Properties Manager.
2- this what i'm usually use is by using -Layer command then choose your need (e.g. OFF) then put your xref name between 2 star(*xrefname*) so it will be like this :
Command: -LA -LAYER
Current layer: "0"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: off
Enter name list of layer(s) to turn off or <select objects>: *Xs-CO-School-1st*
Came here to say that.
@rkmcswain wrote:
@M_Hensley wrote:
In the XREF manager palette just right-click on the name of your xref and select unload to make it go away. Then right-click and select reload to bring it back.^^^^
+1 This has been my preferred method too for years. TOO Simple. 🙂
Don Ireland
Engineering Design Technician
