AutoCAD Forum
External References
6 REPLIES 6
Tony_Gibbs
642 Views, 6 Replies
External References
I have an xref visible in my drawing. This exref has about 30 layers. I want to know if there is a way of turning the entire xref of so I can edit my current drawing and then turn the entire xref back on. It needs to be a quick command like layof and layon
Regards Tony
6 REPLIES 6
imadHabash
in reply to: Tony_Gibbs
there is 2 way for that :
1- xref filter layers from Layer Properties Manager.
2- this what i'm usually use is by using  -Layer command then choose your need (e.g. OFF) then put your xref name between 2 star(*xrefname*) so it will be like this :
Command: -LA -LAYER
Current layer: "0"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: off
Enter name list of layer(s) to turn off or <select objects>: *Xs-CO-School-1st*
3wood
You can try XFT which hides / shows selected xref by one click.
M_Hensley
In the XREF manager palette just right-click on the name of your xref and select unload to make it go away. Then right-click and select reload to bring it back.
rkmcswain
in reply to: M_Hensley
Came here to say that.
R.K. McSwain     | CADpanacea | on twitter
doni49
in reply to: rkmcswain
+1  This has been my preferred method too for years.  TOO Simple.  🙂
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Tony_Gibbs
in reply to: 3wood
Thankyou 3wood
I have registered and XFT works perfect
”Boost
