I failed to install them when i initially installed ACAD (ACAD 2014 Mechanical, part of the Product Design Suite). So i went back through the add remove features and added them. I have the bar now, but none of the commands seem to work. Does anyone have any ideas?
Solved by TKey_Luttrell. Go to Solution.
Type in this line in the command line:
(findfile "txtexp.lsp")
hit enter and see if autocad can find it.
Use windows search, if it can be found, move that .lsp into EXPRESS folder.
I posted this a while back when someone else was having trouble with express tools it may well not be your answer but might be worth checking
I am currently running Autodesk Product Design Suite standard 2013
I know when it was first installed I had the same issue in that I could see express tools some worked but this one did not.
Not sure if this will help you but if you go to the control panel on your PC & wherever you can change programs (on mine its programs & features) find your Autocad & just check that where you can make changes etc that express tools is ticked. For some reason mine was not & making this change solved it.
Sorry if I am suggesting what you have already tried /checked
i had asked this question elsewhere at another time and got an answer
