On AutoCAD 2014, using exportlayout command and saving to a new dwg file, it changes the entire drawing scale on model space, sometimes by 10, somtimes by 20, only once it exported with the real scale. For examle on the source layout I have a sheet frame sized A1 - 841/594 units (mm), on the destination file in model space it becomes 8410/5940 units - all objects and annotative dimensions are displayed exactly as it should but much larger.
I have the feeling that it is only a matter of system variable or another setting. Any suggestions?
@vanessa.hall wrote:
We are very sorry, but a drawing exported by the EXPORTLAYOUT command model scale information is lost.EXPORTLAYOUT command may limit some, so for more information please refer to the below help:Export layout to model space
Link is 404.
DJ
Well, it did not solve my problem, it just tell me that it could happen ("In addition, objects are transformed and often scaled").
If only i could know why, I could adapt the drawing.
Any other suggestions?
