AutoCAD 2013/2014/2015
Member
s.sagi.levy
Message 1 of 2 (1,763 Views)
Exporting DWG to EPS
1763 Views, 1 Replies
04-24-2013 04:47 PM
I am trying to export my document to eps, but it generates an empty file without any error message. My file contains several object arrays. Can this cause a problem during the file format conversion?
I would be grateful for any advice how to debug such a problem.
pendean
Message 2 of 2 (1,739 Views)
Re: Exporting DWG to EPS
04-25-2013 06:28 AM in reply to: s.sagi.levy
Not enough info.
Try using PLOT command instead of 'export': if you don't have a predefined EPS plotter to select you can crate one using PLOTTERMANAGER command's Add-a-plotter wizard, select My Computer, then Adobe (and pick your postscript option). Remember to edit the resulting PC3 file's Custom Properties and ensure EPS and not PS is selected as the output format.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
