AutoCAD Forum
Export .prj file from AutoCAD
3 REPLIES 3
s-nmcleod
9046 Views, 3 Replies
Hi All!
I’m trying to convert a .dwg into a geo-located .shp file, so as a preliminary step I am geo-locating the file in AutoCAD using the GEOGRAPHICLOCATION command and then converting the file through ArcGIS.
Now I save the file with a geographic position 'embedded', but a .prj file is not generated which means the geolocation is not recognised in ArcGIS. The only reason I know it should be is because when this in testing this out yesterday, a .prj file was saved when the .dwg was saved. Then when I imported the .dwg into ArcGIS, it recognised a location. Otherwise it errors out.
Are these .prj files interchangeable based on the mapping grid system, or are they specific to the geographic marker?
Thanks all for your help.
Nicholas McLeod
3 REPLIES 3
Milius
in reply to: s-nmcleod
Export of .prj files just possible in AutoCAD Map. So I think you have th change the forum.
jggerth1
If you want to export entities (lines, polygons, text or points) from a DWG to an SHP, then you need to be using Map3D.  Set you draing up on a coordinate system instead of the 'geolocation'.
There is no 'convert a drawing to shape' ability in any of the Acad applications.
You can use the mapexport command to export DWGs as shapefiles.
”Boost
