AutoCAD 2013/2014/2015
Member
sgdunn
Message 1 of 6 (2,013 Views)
Accepted Solution
Explode a block only
2013 Views, 5 Replies
03-28-2013 01:03 PM
I have a situation where I have a drawing with 3D faces creating the Chassis of a desk, and the top and pulls were inserted from other drawings and are blocks.  There are numerous drawings with this scenario and I am looking for a way to explode the blocks ONLY in the drawings without exploding the 3D faces as well.  Then we'd like to purge the drawing of the nested blocks before saving it.
I'm not a programmer so any help would be greatly appreciated.
I've attached a sample of one of the files in question.  I'm hoping there is a solution that doesn't require us to open each drawing individually as there are hundreds of them...if not thousands.  We didn't catch this 'mistake' until today and have created many, many product lines (started in November) with this issue.
Thanks in advance for your help.
Not the answer, but maybe this will help:
3dfaces don't explode.  The standard autocad Explode command will leave any it finds in your selection set intact.  3dfaces that have been turned into regions will explode though.
You can use either the QSELECT or the FILTER command to grab only the blocks in a drawing.  Then you can process them in each drawing as you see fit.
To process hundreds of files, unless there's a canned 3rd party solution out there for you, I'd say your best bet would be to look into autocad scripts.  Scripts may be written to open a file, run a bunch of autocad commands from the command line, close the file, and then move on to the next file and repeat.  They are among the easiest forms of Autocad programming to learn and put to work.
Action macros may provide another avenue for you to explore.  Even simpler than scripts.  Not sure though whether you could get them to process a list of files without stopping for user input.
Be forewarned that before processing files in batches, save a copy of your original files elsewhere.
Hello from France
Pre-requisite, you have pre-loaded the "EXPBS.lsp" routine and it's avaliable with ANY DWG !
This routine "EXPBS" explode ALL Blocks , even Blocks inside Blocks !!
In theory with the following Script file >>>
EXPBS
-PURGE
_BL
_N
_SAVEAS
After _SAVEAS you have to complete the Script ...
and Open the Next DWG and so one ...
So Good Luck, Bye, Pat
Valued Contributor
qupola
Message 2 of 6 (1,971 Views)
Re: Explode a block only
03-28-2013 06:30 PM in reply to: sgdunn
*Expert Elite*
braudpat
Message 3 of 6 (1,949 Views)
03-29-2013 08:58 AM in reply to: qupola
Hello from France
EXPBS
-PURGE
_BL
_N
_SAVEAS
Bye, Pat ( Supporting Troops )
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Compliment) - Thanks
Valued Mentor
hardin
Message 4 of 6 (1,942 Views)
03-29-2013 12:39 PM in reply to: sgdunn
Use QUICKSELECT to select only blocks, then explode them.
You can also use the FILTER command for more options.
QUICKSELECT is found on the Properties Manager (upper right icons) and can also be found the the pop up screen menu depending on how your mouse controls are set up. For me, I just right click and hold for a quarter of a second.
For you, it may be a quick right click, a middle mouse click or any number of things.
Member
sgdunn
Message 5 of 6 (1,903 Views)
04-02-2013 09:17 AM in reply to: sgdunn
I used a combonation of the first two replies.  I wrote a script executing the LSP routine and used ScriptPro to run it.  Worked like a charm.
Thank you all for the input!
Distinguished Contributor
Justin2012
Message 6 of 6 (1,770 Views)
06-11-2013 02:04 PM in reply to: sgdunn
On another note, how can I restrict to explode or doing changes on a block?
Please advise.
Thx
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
