AutoCAD Forum
excel sheet into autocad Lt 2014 doesnt show
4 REPLIES 4
klaranepustilova
359 Views, 4 Replies
I have a problem with copying excel sheet into autocad Lt 2014. It does work to me normally pretty good, but this time I did turn UCS (it may be the problem) because I need different view and when I copy the sheet in autocad (ctrl C ctrl V or paste special) it appears just empty frame. The layer is turn on.
can anyone help me, please?
Thank you
4 REPLIES 4
This is a known issue with OLE objects (OLE is what you get when you copy+paste in an Excel spreadsheet).
Suggestion: Print your excel spreadsheet to PDF and insert that PDF as a reference into your DWG file.
R.K. McSwain     | CADpanacea | on twitter
Hi, ok, thanks. I hoped it is some way how to fix it... but pdf works as well.
try using RTDISPLAY system variable. I believe it's either 1 or 0. If it's 0, try changing it to 1.
Hi, thank you, I tried it (RTDISPLAY) but it didnt help. Also insert pdf underlay didnt work to good. From some reason there are some strange lines and text is almost imposible to read. It never happened to me.
”Boost
