AutoCAD 2013/2014/2015
Active Member
ehillkeast
Message 1 of 5 (1,200 Views)
Excel Data Link
1200 Views, 4 Replies
11-01-2012 08:41 AM
When trying to insert a table linked to an Excel 2010 file, it works up until row 28, however, as soon as I add  a 29th row to the table it no longer inserts the table. When I try and insert it, I press ok and nothing happens. I tried inserting it as a smaller table and changing the data link to a bigger range after it was inserted, it just didn't update to a larger range.
Is there a way of getting this to work without having to insert it as two different tables?
Thank you,
Eric
Valued Contributor
mailbox
Message 2 of 5 (1,178 Views)
Re: Excel Data Link
11-01-2012 03:16 PM in reply to: ehillkeast
This is no answer but you shouldn't have a problem I have inserted tables with over 100 lines, all I can think is there is somthing in the table causeing a problem.
If you want to attach the table I will have a look for you.
Active Member
ehillkeast
Message 3 of 5 (1,166 Views)
Re: Excel Data Link
11-02-2012 05:46 AM in reply to: mailbox
Thank you,
I think it was a problem with the file. I saved it as an xls as opposed to an xlxsx and it worked.
New Member
super4section
Message 4 of 5 (603 Views)
Re: Excel Data Link
02-13-2014 06:47 AM in reply to: ehillkeast
New Member
super4section
Message 5 of 5 (601 Views)
Re: Excel Data Link
02-13-2014 06:49 AM in reply to: super4section
visit super-section.com
for LS, CS, Drawing, or Design-drawing and Estimation by linking Excel with AutoCAD
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
