Etransmit won’t work. It doesn’t crash. It is gathering all the xreferenced files of the xreferences and any other file in the Work folder it can find. It spends about an hour doing this, and you end up with an etransmit zip file that is 200 MB with 330 files instead of the6 files that it should have.
I did everything in the following thread
http://forums.autodesk.com/t5/AutoCAD-2013-2014-2015/Autocad-2014-Fatal-error-on-etransmit/td-p/4310...
The Graphics hotfix worked until I had a fatal error. After the fatal error, nothing in the thread worked.
Please help!
Meredith
C3D 2014
Windows 7 64 bit
