This morning, I got the following error. I tried a repair, but still will not open a drawing?
Any ideas?
Hi Kevin,
Please try resetting your AutoCAD. Go to Start > All programs > Autodesk > AutoCAD 2013 > Reset settings to default.
If that does not work, go to your control panel and Repair AutoCAD 2013
If all else fails, please do a clean uninstall, clear the temp folder and reinstall.
Please let me know if you need help with any of these suggestions.
An internet search seems to indicate that this is a file for Mechanical. If that is true, do you have access to any other computers that also have Mechanical on them? The file appears to reside in "program Files\Autodesk\mdt6 (or whatever version you have)\sys". Maybe you can find a copy of the file on another machine and copy it over to your directory. Worth a shot.
